Results 1 to 10 of 12
Thread: Building a gate the right way - GIF
  2. The Following 9 Users Say Thank You to Altair For This Useful Post:
    clydeman (Apr 2, 2022), Duke_of_URL (Aug 19, 2025), emu roo (Aug 19, 2025), EnginePaul (Apr 2, 2022), KustomsbyKent (Apr 1, 2022), mwmkravchenko (Apr 1, 2022), NortonDommi (Apr 2, 2022), Ralphxyz (Apr 1, 2022), Toolmaker51 (Jan 17, 2023)
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Would it work OK if you bolted the ends of the diagonal, putting it in tension? Carl.
  4. The Following User Says Thank You to carl blum For This Useful Post:
    piper184's Avatar
    Jul 2016
    piper184's Tools
    Of course. I was taught to always put members in tension, because if they are in compression they can deform perpendicular to the force applied and bend out of shape.
    Compression works fine as long as the member itself has enough rigidity to withstand any side loads that are imposed. Wood would definitely warp and cause issues under compression unless massively oversized. This adds weight and expense.
    Think about if you were using twisted wire as the diagonal brace, you would want it in tension as it is useless in compression.
    Because the tension member was not properly anchored in this video, it is miss-leading.
  6. The Following User Says Thank You to piper184 For This Useful Post:
    When in doubt just add make it an X then you are covered either way.LOL
  8. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Aug 19, 2025), marksbug (Apr 6, 2022)
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Quote Originally Posted by piper184 View Post
    You are correct. A turnbuckle and rod would only work one way but a properly attached wood member would work in the same orientation as the rod or opposite.
    Who is this miss-leading. Is she pretty?
  10. The Following User Says Thank You to Floradawg For This Useful Post:
  11. #6
    piper184's Avatar
    Jul 2016
    piper184's Tools
    miss-leading is the sneaky sister of miss-guided and miss-spelled!
  12. #7
    Yes, but question was, is she pretty. Inquiring minds want to know
  13. The Following User Says Thank You to Frank S For This Useful Post:
  14. #8
    piper184's Avatar
    Jul 2016
    piper184's Tools
    That depends on if it is closing time or the morning after.....
    Eye of the beholder and all that.
  15. The Following User Says Thank You to piper184 For This Useful Post:
  16. #9
    So you are saying that the more adult beverages consumed the better looking they get. My problem there would be I would wind up with miss-stake instead
  17. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Aug 19, 2025), piper184 (Apr 3, 2022)
  18. #10
    Jul 2018
    Flora, MS
    Floradawg's Tools
    The girls all get prettier at closing time.
  19. The Following User Says Thank You to Floradawg For This Useful Post:
