Building a gate the right way.
Turning sliding gate - GIF
Seatbelt buckle gate lock - GIF
Terrible gate - GIF
Automatic driveway gate - GIF
Kissing gate - photo and video
Weight-sensitive drive-over wooden gate - GIF
Terrible gate - GIF
clydeman (Apr 2, 2022), Duke_of_URL (Aug 19, 2025), emu roo (Aug 19, 2025), EnginePaul (Apr 2, 2022), KustomsbyKent (Apr 1, 2022), mwmkravchenko (Apr 1, 2022), NortonDommi (Apr 2, 2022), Ralphxyz (Apr 1, 2022), Toolmaker51 (Jan 17, 2023)
Of course. I was taught to always put members in tension, because if they are in compression they can deform perpendicular to the force applied and bend out of shape.
Compression works fine as long as the member itself has enough rigidity to withstand any side loads that are imposed. Wood would definitely warp and cause issues under compression unless massively oversized. This adds weight and expense.
Think about if you were using twisted wire as the diagonal brace, you would want it in tension as it is useless in compression.
Because the tension member was not properly anchored in this video, it is miss-leading.
