5 Attachment(s)
Building a Homemade Trailer
My wife and I needed a small trailer for things around the house. The trailer has a few things that makes it a bit different than your store bought trailer. Will added more pictures of the build in the next few post and show some of the things that makes this trailer different. Well here the final job. Vernon
10 Attachment(s)
Tail Gate/Ramp Part 1 of 3
Part one is framing of the Gate/ Ramp. Outside is 1" X 2" by 11 gauge Rectangle tubing. The three other supports are 1 1/4" by 11 Gauge SQ Tubing. 1" Sch 40 pipe makes the top and bottom.
9 Attachment(s)
Tail Gate/Ramp Part 2 of 3
Part two shows the locking system for gate and gas shocks. The lock system is made up of two springs two split set collars two 1/2" stainless shafts and one stainless cable. The Gas cylinders are 250 lbs each and makes the Gate/Ramp almost weight less in most positions.
5 Attachment(s)
Tail Gate/Ramp Part 3 of 3
Part Three is away to make a trailer longer when you need that extra 4 feet to haul it home. The picture should explain it. The cables are good for 1000 LBS each and are made from 3/16" cable with quick snap hooks on each in. Also light covers are on.
