1 Attachment(s)
Bump Center QCTP Style
Easy project. Just some 1018 steel, two cap screws, 4 set screws, two small bearings, and a chunk of aluminum.
Great tool for a quick centering aid. After centering with the "bump" I check it with the indicator and it is usually quite close, just a bit more tweeking and it is good to go. I made up 3 dovetail tool holders and left them un-drilled. When I know what I want to use the tool holder for I drill it as necessary. Nice to have a couple of blank QCTP holders on hand.
Cheers, JR
Thanks jjr2001! We've added your QCTP Bump Center to our Machining category,
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-qctp-bump-center">
<img src="/uploads/158273/homemade-qctp-bump-center.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-qctp-bump-center">QCTP Bump Center</a>
<span> by <a href="http://www.homemadetools.net/builder/jjr2001">jjr2001</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/centering'>centering</a> </div>
</div>
</div>
</div>
