Results 1 to 10 of 10
Thread: Bump Switch
    Supporting Member Geffre's Avatar
    Dec 2015
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Geffre's Tools
    Bump Switch
    Bump switch.
    Bump Switch-img_0001.jpgBump Switch-img_9998.jpgBump Switch-img_9997.jpgBump Switch-img_9996.jpgBump Switch-img_9995.jpgBump Switch-img_9994.jpgBump Switch-img_9978.jpgBump Switch-img_9977.jpgBump Switch-img_9976.jpgBump Switch-img_9975.jpgBump Switch-img_9999.jpg
    Link to video of the action.
    The best safety gear is between your ears. Stay alert, stay awake, stay sober so you can stay alive. Also, if I had the money, there is a brand of saw I would “stop” traffic to bring home. But in the mean time, I use older saws trying always to use my best safety feature.
    Older table saws have lots of great features. Iron table for magnetic jugs, belt driven for quieter performance, replaceable motor so increased power is only a swap away.
    However, safety features are more dependent on the user. One problem I tried to solve is the switch. Most older saws use a light switch, which is cheap and easy for people to replace. However, you need to take one hand of the work to operate it.
    Bump switches are much safer since you do not need to take your hands or your eyes of your project. Most accidents happen when we are distracted. If the switch is at hip level, an easy bump can shut down the whirling finger snatcher.
    I used what I had around the shop; wood, printer parts, and glue. I purchased the toggle switch and the face plate, under $4.
    I hung the bump plate above the switch so that it would hit the off section of the switch. The spring is from a printer I disassembled, along with the rubber wheels.
  2. The Following 5 Users Say Thank You to Geffre For This Useful Post:
    dubbby (07-13-2020), Jon (07-12-2020), mwmkravchenko (07-08-2020), Paul Jones (07-13-2020), Toolmaker51 (07-08-2020)
    Apr 2014
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gadgeteer's Tools
    I'm, usually, pretty good at discerning how something operates, but I'm not seeing this one. Do you have a video you can post that shows how the bump switch functions? Thanks!
    Dec 2015
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Geffre's Tools
    Needed to figure how to post a video. Ended up adding a YouTube link instead.
    Apr 2014
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gadgeteer's Tools
    Makes perfect sense, now. Thanks!
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Geffre! We've added your Bump Switch to our Switches category,
    as well as to your builder page: Geffre's Homemade Tools. Your receipt:
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    katy's Tools
    You talk about safety and then the cables going into the switch box are unsafe. The one on the left has an improper connector and from what I can see, the one on the right doesn't even have a connector.
  8. #7
    Dec 2015
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Geffre's Tools
    I will have to fix that. What is the correct connection?
  9. #8
    Apr 2014
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gadgeteer's Tools
    Quote Originally Posted by katy View Post
    Good catch, katy! I was so interested to see how the bump switch worked, I missed the wiring.
  10. #9
    May 2014
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Convoluted
    Quote Originally Posted by Geffre View Post
    Bump switch.
ID:	35713Click image for larger version.
ID:	35722Click image for larger version.
ID:	35721Click image for larger version.
ID:	35720Click image for larger version.
ID:	35719Click image for larger version.
ID:	35718Click image for larger version.
ID:	35717Click image for larger version.
ID:	35716Click image for larger version.
ID:	35715Click image for larger version.
ID:	35714Click image for larger version.
    That sort of switch is already a bump switch. To make it easier to bump, simply hinge (in the same manner as you have) a flat 2" x 4" board with a hole in it. Use the hole to push the switch on. Bump the board to turn off. No need for a spring.
  11. #10
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    katy's Tools
    You can use either straight or angle connectors. Sometimes the cable is too small for the connector so you have to build it up, DO NOT use tape to enlarge the cable as it will gradually slip over time. Strip the jacket off of an extra piece of cable and wrap it around the cable.
    Name:  straight cable connector.jpg
    Name:  angle cable connector.png
    Post your reply!
    eBooks for Supporters
