Results 1 to 10 of 13
Thread: Calibrated inline boring bar
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    As I am at a stage to start machining the cylinder block for my 3” Foden steam wagon, I found my inline boring bars out which I made a few years back. The bars are made from stock diameter mild steel bar and range from 1” diameter to up to 2” diameter.
    An inline boring bar is used to cut parallel radius or diameters. Unlike a normal boring head in a milling machine, the inline boring bar is placed between centres on a lathe, with both end’s of the bar being supported this makes the tool very ridged with less chance of any tool deflection. The bar is driven from a lathe carrier against a catch plate. The material once set in the correct position is clamped to the lathe cross-slide and and fed along the bed while the boring bar rotates cutting the component.
    The way I have seen most inline boring bars made is too simply drill a hole in a round stock of mild steel, for a piece of high speed steel to be clamped with a grub screw to hold it in place.
    Below is an example of this simple style inline boring bar, I made years ago.
    These work really well but are lacking the fine adjustment that is needed when trying to bore an accurate diameter or radius.
    My solution to this problem was to use an item already on the market and adapt it for my needs. Devlieg micro bore cartridge. These are normally used in production. The boring tools would be setup in a tool room to cut the desired diameter or diameters. I say diameters as it is possible to set more than one cartridge to a custom boring bar. These can be used for roughing or finishing or both
    The cartridge fits into a pocket with two slots. The cartridge has two keys which fit into these slots to prevent the cartridge from rotating when adjusting. There is a clamping screw at the bottom of the cartridge which is loosened to adjust the cartridge and locked up once set to prevent any further movement.
    With this setup it is a lot easier to cut an accurate diameter or radius.
    To cut larger radius, I made an adjustable holder out of mild steel and held this in the traditional way an inline boring bar would hold the high speed tool bit, but in the end of the steel I added the micro bore cartridge for fine adjustment. This allows the tool to be adjusted roughly to the desired radius but still have the option to feed the tool out to the finished diameter.
    The photos below will hopefully clarify the inline boring bars.
    Calibrated inline boring bar-e1e3e70d-c493-452a-a999-ce4e2bcccef6.jpegInline boring bars
    Calibrated inline boring bar-1aa96794-dd01-4e02-88e8-e2ea155a70f2.jpegBar counter bored then centre drilled to prevent any damage to centre if dropped etc.
    Calibrated inline boring bar-96a86597-1bbf-4388-8060-b195e4551123.jpeg Devlieg micro bore Cartridge.
    Calibrated inline boring bar-4b506a1f-4ec9-4781-adae-d4cbb620b909.jpegPocket in bar to accept micro bore cartridge.
    Calibrated inline boring bar-0f7ae6cb-a52d-4f02-8096-57b5b0595114.jpegCartridge in place.
    Calibrated inline boring bar-b5153141-e4aa-4780-a2bd-c9210c9dd15a.jpegLarge radius inline boring bar.
    Calibrated inline boring bar-9c64ceb8-f32b-4322-99ef-541c5697fe6e.jpegAnother view of large radius tool.
    Calibrated inline boring bar-e9cfc85e-6645-4ee6-ab50-6999c195b395.jpegA selection of cartridges purchased from eBay.
    Calibrated inline boring bar-7b64dd5a-0941-4af6-ab93-def48bd1291b.jpegMarking out to show how much material is too be removed. With the adjustment of the cutting tool accuracy is easier to achieve.
    Below is a short video of the tool cutting the chimney saddle casting.
    Thank you for viewing
    The Home Engineer
    Attached Thumbnails Attached Thumbnails Calibrated inline boring bar-659c2aeb-c43b-41d9-89e1-81097a637e00.jpeg
  2. The Following 12 Users Say Thank You to thehomeengineer For This Useful Post:
    asterix (Nov 22, 2022), johncg (Nov 22, 2022), Jon (Nov 21, 2022), metric_taper (Nov 21, 2022), mwmkravchenko (Nov 22, 2022), nova_robotics (Nov 21, 2022), Philip Davies (Nov 20, 2022), RetiredFAE (Nov 27, 2022), Saltfever (Nov 21, 2022), Toolmaker51 (Nov 21, 2022), tooly (Nov 22, 2022), uv8452 (Oct 30, 2024)
    Thanks thehomeengineer! We've added your Calibrated Inline Boring Bar to our Machining category,
    Can sum up my admiration of thehomeenginners boring bar project in one word; DeVlieg! IMONHO, no machine surpasses the accomplishments of that brand and Mr. DeVlieg.
    The DeVlieg Spiramatic Jigmil
  5. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    thehomeengineer (Nov 22, 2022), tonyfoale (Oct 30, 2024)
    Supporting Member jackhoying's Avatar
    Apr 2014
    Fort Loramie, Ohio
    jackhoying's Tools
    Nice work! I have quite a few of the DeVlieg Microbore inserts to sell, if anyone is interested.
  7. The Following User Says Thank You to jackhoying For This Useful Post:
    Berkshire UK
    Hi Jack
    Thank you for viewing. How much are you looking for the cartridges and are you willing to post worldwide? I thank you in advance for your time
    The home engineer
    Apr 2014
    Fort Loramie, Ohio
    jackhoying's Tools
    Quote Originally Posted by thehomeengineer View Post
    Hi Jack
    The home engineer
    These are the ones I have. They would be $145.00 for the lot, shipped to the U.K.
    Jack
  10. The Following User Says Thank You to jackhoying For This Useful Post:
  11. #7
    Berkshire UK
    Hi Jack
    I will have them please. I will private message you with my details.
    thank you again
    Andy
  12. #8
    Hi Jack
    Andy
    Nice buy, not just opportune; because they don't grow on trees.
    If I'd seen them first, well. . .
  13. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    thehomeengineer (Nov 25, 2022)
  14. #9
    Apr 2012
    NorCal
    Saltfever's Tools
    . . . If I'd seen them first, well. . .
    Agree . . . me too. Oh well, "He that snoozes . . . losses".
  15. The Following User Says Thank You to Saltfever For This Useful Post:
  16. #10
    Andy has first dibs and I really hope he gets them Those are one of the brands I was trying to think of the other day in a conversation with TM51 along a similar train of thought for a machine I am considering
  17. The Following User Says Thank You to Frank S For This Useful Post:
