Results 1 to 6 of 6
Thread: Can Measuring your Spindle's Electrical Resistance Indicate the Lubrication Level?
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    The short answer: I don't know.
    However, I just completed a survey that implies that you can characterize your machine and know when your bearings are dry using an ohmmeter.
    If you are interested, please, click here
    Thanks,
    Rick
    Rick
  2. The Following 5 Users Say Thank You to rgsparber For This Useful Post:
    drivermark (Jun 12, 2022), Frank S (Jun 5, 2022), Inner (Jun 6, 2022), Jon (Jun 12, 2022), nova_robotics (Jun 6, 2022)
    Sep 2018
    nova_robotics's Tools
    That's some good work there Rick. One tiny note, I done goofed on the data I gave you. I gave two values for resistance, for example 0.09 and 1.2, were for stationary and rotated respectively. The low value was for a stationary spindle, the high value was for the rotated spindle. I just got it in my head that rotated would always produce a lubricant film and be higher resistance, but I forgot to actually write that. Sorry about that.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Thanks for the correction. I see other entries where I misinterpreted the same way. All corrected now.
    I am reminded of a comment made by one of the designers of Auxiliary Power Units that are used in jets. He said they use magnetic bearings so when running at the full 50,000 RPMs, the spindle does not touch the housing. However, when stopped, the spindle rests on the housing. I asked how you get from stopped to full speed without tearing things up. He just smiled and said that is where the magic occurs.
    Rick
    Sep 2018
    Hard drives have all switched to air bearings. The spindle floats on an air bearing, and the heads float above the surface of the magnetic disc because the boundary layer effect causes the heads to "fly" just off the surface, which is also essentially an air bearing. What happens when the hard drive is spinning up or spinning down? More magic I guess.
    Mar 2018
    West Lafayette, Indiana
    As far as the read/write heads go, each platter has a ‘landing zone’ where no data is stored. Often, the zone is coated with a low-friction material to protect the head.
    Sep 2018
    Quote Originally Posted by bob47907 View Post
    Yup. But what about the spindle bearing?
