Looks nice! :)
Looks nice! :)
Thanks Metalmuncher :)
Well done!
I envy your acquiring a Dore Westbury mill, I always wanted one but could not afford the castings at the time.
The one you have looks to be well made, a nice machine for the model engineer.
Very nice - it looks like a heavy-duty, industrial grade version of the one I built a few years ago. This is my small one with an octagonal broach installed:
Attachment 19956
Here's the description and a detailed drawing:
A Simple, Compact Rotary Broach | The Hobby-Machinist
Hi,
A question about the choice of some dimensions, you have a relative short length to support the broach, on a too high speed accidently, it makes some vibrations and a less good interior finish with waves, when I made one time ago without your measures, with a longer distance between the ball and the set screws, it have a more stable use than the one made shorter now.
What rpm speed do you use please ?
It's really not to criticize your construction, just an observation in workshop use.
Have a niice day.
Pierre
In all honesty' I haven't used it yet :p
Got a few jobs that will need it coming up though so will report back once I've run it.
Thanks Canobi! We've added your Rotary Broach to our Machining category,
as well as to your builder page: Canobi's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-rotary-broach-11"> <img src="/uploads/238958/homemade-rotary-broach-11.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-rotary-broach-11">Rotary Broach</a> <span> by <a href="https://www.homemadetools.net/builder/Canobi">Canobi</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/broach'>broach</a> </div> </div> </div> </div>
Thanks Canobi! We've added your Dividing Head and Collet Drawbar to our Machining category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-dividing-head-and-collet-drawbar"> <img src="/uploads/238963/homemade-dividing-head-and-collet-drawbar.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-dividing-head-and-collet-drawbar">Dividing Head and Collet Drawbar</a> <span> by <a href="https://www.homemadetools.net/builder/Canobi">Canobi</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/collet'>collet</a>, <a href='https://www.homemadetools.net/tag/drawbar'>drawbar</a> </div> </div> </div> </div>
