Results 1 to 7 of 7
Thread: Casting an aircraft engine in the 1930s - photo
    Altair's Avatar
    neilbourjaily (10-29-2020), nova_robotics (10-29-2020)
    Lake Tahoe
    IntheGroove's Tools
    If you're casting jugs you better be wearing a jughead hat...
  4. The Following 2 Users Say Thank You to IntheGroove For This Useful Post:
    neilbourjaily (10-29-2020), Toolmaker51 (10-31-2020)
    Jughead indeed....though I couldn't recall character's name. Reason for hat unclear, but wearers were typically mechanics...
    Only apparent decent reference https://en.wikipedia.org/wiki/Whoopee_cap
  6. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    IntheGroove (11-01-2020)
    Apr 2016
    I love a nice pair or 2 of jugs....
    Unkle Fuzzy's Avatar
    Near Monkeytown, USA
    Big jugs too......
    As a side note, the reason for the large number of cylinders on radial aircraft engines?
    It was found that anything over about 6" in bore the cylinder and head generated so much heat it could not be reliably cooled by air. as a general rule air cooled engines are limited to bores of 6" or less while liquid cooled engines can go much bigger.
    Apr 2016
    more jugs are just better. I need to make some for 2 of my projects...someday.aluminum with iron liner, I cant afford the SUM bore or the Nikisill stuff. I have some china nikisill in 2mm smaller bore than what I need, but already have some expensive "trick" pistons and not sure I want to trust these china ones even on the smaller bore.(92mm) if I didnt already have these pistons I would go with 100.1mm bore....or bigger.
  10. #7
    Dry Gulch, Tx
    Crusty's Tools
    And he didn't need to watch some videos on Youtube to do it either.
    Post your reply!
    eBooks for Supporters
