Results 1 to 4 of 4
Thread: Casting a die from fasteners - GIF
    May 2024
    Casting a die from fasteners.
    1920s Demley mechanical dice - GIF
    Dice dotting machine - GIF
    Laser engraving wooden dice - GIF
    Round spinning dice set - video
    Floradawg (Jun 11, 2024), Ralphxyz (Jun 16, 2024), robbitalia18 (Jun 16, 2024)
    Supporting Member basil3w's Avatar
    Mar 2012
    What was the glass for?
    Quote Originally Posted by basil3w View Post
    If you look carefully once the brass is melted the impurities are drawn off in a single lump. that is the glass drawing the impurities together
    Aug 2012
    Australia
    desbromilow's Tools
    I use clear glass, not coloured. I was told that it melts and forms a "skin" over the molten metal to prevent air coming in - thereby reducing the amount of created slag/ dross. As Frank indicated, it helps pull the dross together as well making it easier to remove.
