Thread: Center-to-Center Hole Measurement Inserts
    Supporting Member MetalDesigner's Avatar
    Sep 2013
    Las Vegas ~ @MetalDesigner Twitter
    MetalDesigner's Tools
    3D Printed Center-to-Center Threaded Hole Measurement Inserts
    CLICK HERE for More Images & Video:
    https://ctmprojectsblog.wordpress.co...ement-inserts/
    Center-to-Center Hole Measurement Inserts-0.375-inch-machine-bolt-version.jpg
    Many years ago ~ I use to work inside ships aligning & welding items, and if you have ever been inside a ship you know nothing is straight, level, or easy (Other than creating a leak) …
    Therefore, one needs to be able to mount ‘measurement items‘ in specific places and measure out from those areas to triangulate distances, etc.
    Several years ago I machined some measurement guides out of Aluminum for Centering threaded holes and made magnetic mounts for some of the hole measurement inserts.
    Decided to design a version to 3D-Print up several new ones for a current project …
    3D-Printing allowed me to design without having to worry about 'plastic injection molding' draft angles.
    Center-to-Center Hole Measurement Inserts-end-tape-locked-into-center-hole.jpg
    The Key to the design is one edge is perfectly aligned with the Center of the hole so that when the tape is pulled against that edge it aligns with the center of the hole for measuring Center-to-Center hole measurements.
    My AFINIA H-480 3D-Printer creates very accurate parts allowing the center hole measurement to line up very well with the 3D-printed insert edge ….
    3D-Printing Resolution for the AFINIA H-480 is 0.20mm ( 0.0079″ )
    The Measurement Inserts are also designed so they are exactly 1/2″ from any flat edge to the center of the hole being measured with the Tape …
    Many times I will run a guide string to get a visual of where items are going to run through other structures for which I am designing my items to fit within …
    Created a quick ( unedited ) Video talking about how I use these items …
    Nothing Fancy but they work for what I need.
    CHEERS!!
  2. The Following 11 Users Say Thank You to MetalDesigner For This Useful Post:
    C-Bag (May 12, 2016), DIYer (May 13, 2016), durrelltn (Dec 14, 2025), emu roo (Dec 7, 2024), HUMARIA (Aug 20, 2019), johncg (Dec 4, 2022), Jon (May 12, 2016), lassab999 (Dec 5, 2022), Paul Jones (May 13, 2016), PJs (May 14, 2016), Toolmaker51 (May 15, 2016)
    Thanks MetalDesigner! We've added your Hole Measurement Inserts to our 3D Printing category,
    as well as to your builder page: MetalDesigner's Homemade Tools. Your receipt:
    emu roo (May 22, 2026)
    Sep 2013
    UPDATE ~ Aluminum Machined Center-to-Center Hole Measurement Inserts
    I was asked for more information about the machined Aluminum version I made a while ago ...
    These are the general dimensions I used to make the 1/4" machine screw aluminum version
    Tried to keep the drawing simple ... I'm sure you can figure it out.
    ( Started with 1" Diameter Aluminum Round )
    Center-to-Center Hole Measurement Inserts-dewalt-dwht-33373-tape-measure.jpg
    Also ordered a couple more of the DeWALT 33373L Tape measures ~ Work Great!!
    Link to Full Website Post:
    Transfer Screw Sets work great for short distances when marking threaded holes
    http://www.amazon.com/gp/product/B00...d_bhz_bw_c_x_1
    CHEERS!!
  6. The Following 4 Users Say Thank You to MetalDesigner For This Useful Post:
    C-Bag (May 20, 2016), emu roo (May 22, 2026), PJs (May 21, 2016), Toolmaker51 (Dec 5, 2022)
