Results 1 to 10 of 11
Thread: Ceramic polishing a wheel - GIF
    Altair's Avatar
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    johncg (Nov 29, 2021), Moby Duck (Nov 28, 2021), mwmkravchenko (Nov 30, 2021), rlm98253 (Nov 27, 2021)
    May 2015
    Tasmania, Australia
    Bony's Tools
    Using ultrasonics ? Certainly works anyway!
    Jan 2015
    Probably more like rock tumbling, with various steps of polishing media...and lots of time.
    hemmjo's Tools
    I would be happy with the finish after the first round with the course media.
    Jan 2016
    Moby Duck's Tools
    Nice but I will bet it took a lot longer than that.
    Sep 2015
    Kansas
    I have used vibratory tumblers at places I worked before. We mainly used them for deburring machined parts. They work really well. Each grit of polishing media takes hours to do what the guy in the video did. The good part is you can just let it run while you're doing something else.
    I didn't want to spend the money for one of those for my home shop ($2500-$4000), although I may get one at some point. I got a $300 cement mixer with poly tub and use that with the coarse ceramic media and a small amount of Dawn dishwashing liquid. The Dawn helps keep the media from loading up with metal particles. It does a pretty good job, but takes longer. The finish with the coarse media is similar to a very fine zinc coating look.
  8. The Following User Says Thank You to Toolguy For This Useful Post:
  9. #7
    hemmjo's Tools
    did you take the paddles out of the mixer?
  10. The Following User Says Thank You to hemmjo For This Useful Post:
  11. #8
    Sep 2015
    Kansas
    Yes, they were metal. I made some 3" tall plastic ones to replace them.
  12. The Following User Says Thank You to Toolguy For This Useful Post:
  13. #9
    Supporting Member schuylergrace's Avatar
    Sep 2020
    I wonder about work hardening with this process. I made a batch of mounting tabs out of 16 gauge aluminum sheet and decided to run them through my cheap ceramic polisher to clean them up. They all came out with a nice finish, but they were also very brittle from work hardening. Still, surface hardening shouldn't hurt those wheels (and might actually protect them), while it could penetrate all the way through my thinner stock.
  14. #10
    Sep 2015
    Kansas
    I have never had work hardening with my parts. They are either 6061-T6, 2024-T3, or 7075. Maybe you had a different alloy?
  15. The Following User Says Thank You to Toolguy For This Useful Post:
    schuylergrace (Dec 2, 2021)
