Changing lug nuts GIF.
https://diqn32j8nouaz.cloudfront.net...g_lug_nuts.gif
Would be my luck that top nut would have bounced off my forehead and all the rest rolled under the car to the far side. :p
I didn't realize it before I found this GIF, but pit crews are increasingly recruited from among former football players. The average career length is short (though longer than the NFL), and the better crewmen make 6-figure salaries.
Interestingly, Matt Prater, who holds the NFL record for the longest field goal (64 yards), did a one-month stint on a pit crew before he was rejected. More: Former football players make the jump to NASCAR pit crews | The MMQB with Peter King
https://diqn32j8nouaz.cloudfront.net/pitstop.gif
Whodathunk. I sure didn't. Kind of make sense though except for a torn ACL up and down on the concrete.
Ok, I understand how they can remove the lugnuts so quickly, but how do they remount them after a tire change as quickly as shown in the gif? Do the air-powered wrenches have a clip like an automatic pistol that delivers nuts to the wrench?
I had the same question, and poked around a bit. Looks like they glue the lug nuts onto the wheels before the race.
Also, they're using highly-specialized air tools, running on nitrogen, with different on/off torque settings, and spring systems for ejecting the lug nuts once they're loose. I was wondering what happens to stray flying lug nuts. Mostly they're just swept up, then used as souvenirs. However, there are various incidents of stray lug nuts causing damage to people and even cars.
Turns out that there is a lot of wiggle room for pit crews to alter the lug nut changing procedure, and there are various rules made to govern exactly how many lug nuts have to go on, and exactly how. I believe it's easier to gain a half-second or second on a pit stop than it is when the car is actually racing.
Asking for trouble...
<source src="https://diqn32j8nouaz.cloudfront.net/multi_wheel_nut_remover.mp4" type="video/mp4">
</video>
Yup, looks like trouble to me especially on the alloy wheels of today. Also wonder how it works on old dirty used lug nuts. Cute but no Cigar from me!
Also that formula car above and a lot of the high level race cars use a single large nut...toward the end of the Gif you can see the large socket on the end of the impact. And yes they are very trick impacts run on pure nitrogen. Typically I think these single nuts are retained in the impact for re-installation as they only change tires a few times in a longer race or weather issues. NASCAR still uses multiple lug nuts to represent the "Stock Car" theme and are glued in.
Attachment 25306 Attachment 25307
Attachment 25305
I still prefer the knock off wire wheels that my MGB (1965) has. I can change a wheel in about five minutes with nothing but the jack and a lead hammer.
Double stack pit stop. This was the first time I ever noticed the guys brushing off the grill.
<source src="https://diqn32j8nouaz.cloudfront.net/double_stack_pitstop.mp4" type="video/mp4">
</video>
That is not the grill. Those are the front wings for downforce. F1 is all about aerodynamics these days, but the designers do not have a free hand. The rules define very tightly the configuration of what they call the "aero package" but those rules change almost annually. So huge amounts of money are spent developing a configuration which will be scrapped and totally redone for the next years rules.
Perhaps this is just semantics. I always think of the "grill" as that part in front of and protecting the radiator for the cooling systems.
In the video, he it cleaning the aerodynamic surfaces of the front wing, perhaps tire debris or a hotdog wrapper.
Interesting info here in regard to the wing design seen in that double stack video. Sometimes the designs are changed between races.
https://www.autosport.com/f1/news/14...its-front-wing
Obviously these comparisons are cherry-picked; still cool. I also believe the disparity here is due in part to some rule changes over the years regarding pit stops.
<source src="https://diqn32j8nouaz.cloudfront.net/pitstop_comparison.mp4" type="video/mp4">
</video>
To be fair, Red Bull are renowned for being the most efficient and fastest pit team, and the Brabham mechanics were having some problems with the left rear. But yeah that shows how much progress has been made
From the driver's lips to the pit Boss's ears, things such as chasis adjustments, is now communicated by telemetry and telephony (well sort of telephony). 1981? walkie-talky.
It should be noted that current pit crews are comprised of American football players who didn't make the cut for the pros, so they try out for something with a slightly longer professional career. These guys are big, strong, fast, and accept both criticism and orders. The perfect combination!
