Results 1 to 7 of 7
Thread: Cheap Drill Press Improvements
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    From the very first day I bought this drill press (Parkside PTBM 500 C3)
    I had in mind to replace the column that was too poor (a tube 46x450x1.5mm) and relatively short with a solid one
    as well as its base with something more robust and stiffer like a cast iron plate or a steel plate.
    The major problem was at the base; wrong geometry.
    When I push to drill then the main base distorts around the column and starting to move up and backwards losing its verticality.
    I have an older model (PTBM 500 A1) that its base whereas it was sheet metal made;
    I never encountered any distortion issues like in this model.
    Cheap Drill Press Improvements-old-new.jpg Cheap Drill Press Improvements-20150810_192551-crop_1.jpg
    Searching at the junkyard I found this stand that probably once it was a drill press base that later was modified to be used for some other application.
    Its column diameter was 45mm (one millimeter less than the needed) but it wasn't a so big deal.
    The base of the stand was cast iron.
    So I decided to buy it and give a try.
    Cheap Drill Press Improvements-20180114_162435-r.jpg Cheap Drill Press Improvements-191103-r-auto-leves.jpg Cheap Drill Press Improvements-img_20100104_042035.jpg Cheap Drill Press Improvements-img_20100104_044708.jpg Cheap Drill Press Improvements-img_20100104_061435.jpg Cheap Drill Press Improvements-hight-low-3-pos.jpg Cheap Drill Press Improvements-img_20180804_180540-crop.jpg Cheap Drill Press Improvements-img_20180804_201901.jpg Cheap Drill Press Improvements-img_20180805_121018.jpg Cheap Drill Press Improvements-img_20180805_184337.jpg Cheap Drill Press Improvements-img_20180805_185748.jpg Cheap Drill Press Improvements-img_20180805_183547.jpg Cheap Drill Press Improvements-img_20180805_190028.jpg Cheap Drill Press Improvements-img_20180805_191451.jpg Cheap Drill Press Improvements-2.jpg Cheap Drill Press Improvements-3.jpg Cheap Drill Press Improvements-img_20180804_205855.jpg Cheap Drill Press Improvements-img_20180819_093858-crop.jpg Cheap Drill Press Improvements-img_20180819_093858.jpg
  2. The Following 14 Users Say Thank You to kess For This Useful Post:
    almarghi (08-22-2018), billster (08-23-2018), blkadder (08-22-2018), Jon (08-23-2018), olderdan (08-24-2018), PJs (08-22-2018), Rangi (09-16-2020), rlm98253 (12-13-2018), rossbotics (08-23-2018), Seedtick (08-22-2018), Slim-123 (09-15-2020), Texf1 (08-23-2018), that_other_guy (12-09-2018), thoms_here (09-15-2020)
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    Wow, my little Craftsman drill press needs this mod. I was thinking of filling the column with either sand or concrete, but your method is much better. I just wish we had junkyards like this around where I live. Thanks for posting this.
    Ron
    ...Semper Fidelis...
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Hi blkadder,
    Glad that you like it.
    I think that the Craftsman’s base is cast iron made.
    If so you need to replace only the column.
    You can order from your local dealer to cut a piece according to the length of your need.
    The cost isn’t too expensive (perhaps about 1.5$/kg).
    You can use the table to calculate the kilograms according to your column’s dia.
    Regards
    Cheap Drill Press Improvements-axes-dia-kg.jpg Cheap Drill Press Improvements-axes.jpg
  5. The Following 3 Users Say Thank You to kess For This Useful Post:
    blkadder (09-15-2020), Jon (08-23-2018), PJs (12-14-2018)
    Thanks kess! We've added your Drill Press Modification to our Drilling and Drill Presses category,
    as well as to your builder page: kess's Homemade Tools. Your receipt:
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Thanks a lot DIYer
    Regards
    Jun 2020
    engineer steve's Tools
    Nice work! That certainly looks a lot better.
  9. #7
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Thanks a lot
    Post your reply!
    eBooks for Supporters
