Results 1 to 8 of 8
Thread: Cheap-n-Easy tap holders
    Dec 2016
    bobs409's Tools
    This has to be the cheapest and easiest way to make a tap holder. These are made using threaded rod connector nuts and some bolts. Nice thing is they are already drilled and tapped so all you do is drill the hole(s) for the tap and you're done.
    To fit all my taps, I made 3 different sizes. Each one has 2 different sized holes so you pick the one that fits best. These fit everything from my 4-40 up to 1/2 inch taps.
    You could opt to make handles instead of using the bolts.
    Attached Thumbnails Attached Thumbnails Cheap-n-Easy tap holders-dscn1393.jpg   Cheap-n-Easy tap holders-dscn1394.jpg
  2. The Following 32 Users Say Thank You to bobs409 For This Useful Post:
    albertq (May 6, 2024), Andyt (Dec 6, 2018), billster (Aug 10, 2018), bvd1940 (Apr 18, 2018), Captainleeward (Apr 20, 2018), DIYer (Apr 20, 2018), EnginePaul (Aug 10, 2018), fjerceg (Mar 2, 2019), Floradawg (Aug 10, 2018), ftriker (Apr 18, 2018), gmrad (Aug 11, 2018), Gregraper33712 (Apr 19, 2018), gunsgt1863 (Apr 18, 2018), Home-PC (Nov 26, 2020), jjr2001 (Apr 18, 2018), Jon (Apr 18, 2018), kboy0076 (Oct 26, 2024), Miloslav (Dec 5, 2018), Moby Duck (Apr 18, 2018), natie123 (Aug 12, 2018), nova_robotics (Nov 25, 2020), olderdan (Apr 18, 2018), oldpastit (Mar 2, 2019), Paul Jones (Aug 10, 2018), rlm98253 (Apr 18, 2018), Scotsman Hosie (Nov 29, 2020), Seedtick (Apr 19, 2018), sossol (Apr 18, 2018), Steved53 (Apr 19, 2018), thatman (Apr 18, 2018), volodar (Apr 18, 2018), yester145 (Apr 19, 2020)
    I would recommend lock-nuts on the handles. Hand pressure may loosen the bolts while threading. If the hardened tap falls out onto a concrete floor it will break.
    That's why I prefer the style...
    http://www.homemadetools.net/forum/m...p-wrench-61852
    where the tap-holding screws are not part of the handles.
    Thanks bobs409! We've added your Tap Holders to our Tapping and Threading category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
    chucksjc's Avatar
    Looks great. But how does a square tap work in a round hole?
    Oct 2012
    Bob
    Very nice but I think I would go in the direction Marv showed but I would turn the long nut on the outer parts to receive a piece of tubing instead of bolts. The length would be what ever to get the torque required to cut the threads. There is so much could be done with the idea and make a very nice tool.
    Thanks for sharing
    Nelson
    Sep 2012
    Hinchinbrook QLD
    Quote Originally Posted by chucksjc View Post
    Just screw the bolts in and they grip on the flats
  8. #7
    Jan 2016
    Southern tip of Vancouver Island
    The torque end of a tap is of square cross-section. This tap's handles are bolts. They are set against opposite sides of the tap's square end. The tap is now captive in the tapping handle.
  9. #8
    Jan 2016
    "To fit all my taps, I made 3 different sizes. Each one has 2 different sized holes so you pick the one that fits best. These fit everything from my 4-40 up to 1/2 inch taps."
    I'd be tempted to drill the six different sized holes into a single threaded rod connector. Weakening of the connector likely inconsequential. One tool instead of three.
