Results 1 to 7 of 7
Thread: Cheap Packing Tape as a Protective Layer for Labels
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Even flimsy packing tape makes a decent protective covering for paper labels. The problem is that this stuff easily wrinkles and forms bubbles as it is applied. Here is a trick for keeping it much smoother.
    If you are interested, please, click here.
    Thanks,
    Rick
    Rick
  2. The Following 2 Users Say Thank You to rgsparber For This Useful Post:
    Inner (Jan 18, 2022), Toolmaker51 (Jan 19, 2022)
    As I read it: you used the water's surface tension to hold the tape flat onto the glass plate, then you flipped the glass plate and laid the thus flattened tape onto the label already affixed to the black plate smoothing it into place.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by neilbourjaily View Post
    I don’t flip the glass. I mash the plate with label on it down on the tape bedded in a thin layer of water.
    Rick
    Rick
    Mar 2016
    As I use my label maker fairly frequently, I will use this technique, so thank you!
    I didn’t understand what your referring to as “finish” however. 6 drops of what?
    Thanks again!
    Rick in Oregon
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    “Finish” is the name of a product I use in my dish washer.
    Rick
    Rick
    Supporting Member Rikk's Avatar
    Nov 2018
    Rikk's Tools
    A drop or two of liquid dish soap should work as well. When applying decals to race cars and karts, I use a quart spray bottle with water and a couple drops of dish soap. It helps to position the decal without it sticking, then I use a squeegee and heat gun to smooth them out if needed.
  8. #7
    Thanks rgsparber! We've added your Label Protector to our Miscellaneous category,
