My brother used the welding rod on jumper cables trick too, usually 1/8 6010 on the positive terminal. It was a surprisingly good setup for light welding but tended to cook the batteries, so he kept a few used batteries around just for this kind of thing. He used his banks of batteries jumpered together to give him 24 volts.
The current draw on the wire should be much lower.
The gun I bought has an adjustment for feed speed but because it was designed for connecting to a welder and using the trigger to control the solenoid for welding I will be running it hot all the time. Now you have me thinking about adding a solenoid Maybe a truck starter solenoid would work.
