Results 1 to 10 of 19
Thread: The cheapest metal chromium
    Supporting Member Kovanca Polock's Avatar
    Nov 2018
    Polock
    Kovanca Polock's Tools
    Lightbulb The cheapest metal chromium
    The cheapest method of chrome plating
  2. The Following 9 Users Say Thank You to Kovanca Polock For This Useful Post:
    Floradawg (Sep 28, 2021), HobieDave (Sep 28, 2021), Jon (Sep 30, 2021), lassab999 (Oct 4, 2021), mwmkravchenko (Sep 28, 2021), nova_robotics (Sep 28, 2021), Slim-123 (Sep 27, 2021), uv8452 (Sep 29, 2021), wolfpaak (Oct 4, 2021)
    Thanks Kovanca Polock! We've added your Chrome Plating Method to our Miscellaneous category,
    as well as to your builder page: Kovanca Polock's Homemade Tools. Your receipt:
    thirdbike's Avatar
    Mar 2015
    Just a quick question: What metal is the spoon made from other than being non magnetic?
    Nov 2018
    Polock
    stainless steel
    Supporting Member piper184's Avatar
    Jul 2016
    where does the chrome come from?
    Nov 2018
    Polock
    As part of a stainless steel
  8. #7
    thirdbike's Avatar
    Mar 2015
    Puzzle
    Now I'm confused. You're suggesting that two identical metals are used connected to opposite terminals of a 5 volt DC output and screened with a piece of plastic. I've done a fair amount of plating but you're explanation of stainless steel for both the spoon and the metal strip just doesn't seem to make sense - but I am willing to hear the an explanation. That being the case, why not use two pieces of the stainless sheet
  9. #8
    Nov 2018
    Polock
    I did not have two spoons that are not magnets, it is poacure that it does not have a value to obtain a solution.
  10. #9
    Jul 2016
    Been researching this a little today as college chem classes were more than 40 years ago. It seems I have forgotten a lot.
    Anyway, putting stainless at the anode (+) will cause chrome to leach out of the stainless steel. It seems you need a Ph down around 1 and it can form as trivalent or hexavalent. The first being harmless and the second being a really nasty poison. Once in solution though, you can reverse the process and deposit it back onto the cathode (-) although I don't quite understand which version is being deposited. It seems a lot depends on the electrolytic solution and the base metals.
    I do remember a lot of shops that did chrome plating were put out of business when they tightened up the regulations
  11. #10
    thirdbike's Avatar
    Mar 2015
    Still not Clear
    Quote Originally Posted by piper184 View Post
    So if the chrome is leached from the Positive anode then one has to assume that deposition is occurring at the negative cathode. I would think that the parts needing plating would be attached and not another piece of stainless. A better explanation is clearly needed.
