Results 1 to 4 of 4
Thread: Checking a tapered reamer
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    I wanted to see whether these two old reamers had been reground to a morse taper.
    I do not know of any other way to do it easily, so I made this jig.
    Checking a tapered reamer-img_1024.jpegChecking a tapered reamer-img_1023.jpeg
    Firstly I scribed a line on a piece of MDF. Then I took a small disc, about 1/2” dia and screwed it to the line at the right end. Then I took two handy pieces of angle iron, salvaged from something, screwed them down with washers to stop them rising from the pressure of the clamp. Then I put in an old no.3 morse taper sleeve, tapped it along, tight. Then I clamped the bars together. Another disc, about 1&1/4” dia was pushed in from the left as far as it would go, then screwed down on the central scribed line.
    That completed the jig. Trying the reamers, you may just see at once that they are not morse taper, but never mind.
    If it had seemed a good fit, I would have tried one of these:
    Can’t remember at present what it’s called!
  2. The Following 3 Users Say Thank You to Philip Davies For This Useful Post:
    emu roo (Jul 24, 2025), Jon (Aug 5, 2025), PJs (Jul 28, 2025)
    If you have a pair of 1-2-3 blocks, it's easy to accurately measure the taper...
    Measuring tapers
    then compare to tapers in Machinery's Handbook.
    Thanks Philip Davies! We've added your Tapered Reamer Jig to our Measuring and Marking category,
    Feeler gauges.
  6. The Following User Says Thank You to tonyfoale For This Useful Post:
    Philip Davies (Aug 2, 2025)
