Results 1 to 10 of 10
Thread: Chip protection for my lathe
    Most of my lathes have always had a drop down chip deflector for use when turning up close to the chuck. My 65 year old le Blond round head does not and never has.
    A while back I came across a lexan or plexiglass display case window that was shaped in a large radius and nearly 6 ft long I thought that it might make a perfect view window for use on the old lathe.
    I first cut it down to size then split a length of 1/2" SS tubing to put on the leading edge to not only stiffen the plastic but to serve ad an edge protector and a convenient handle to raise it out of the way.
    Next I will have to make a mount and pivot for it to mount it with Hopefully I will be able to find a pair of gas spring struts to hold it up
    I used silicone to secure the tubing to the edge so the kitten and puppy had to inspect the knot to make sure it was going to hold together
    Paul Jones (Jun 10, 2018), PJs (Jun 11, 2018), Seedtick (Jun 10, 2018), zarembak (Jun 10, 2018)
