Great description you found NortonDommi. Those large diameters would clearly generate better than smaller. Most of the home-size wind units are barely alternator size; the real ground-breaker seems being the Honeywell, essentially magnets carried at tips of propeller, many many additional segments. A stack of smart drive pancake units would be serious potential indeed.
To you and jdurand alike, what is the attraction or features of washer motors sought in powering small machines? Treadmills are obvious being compact and variable by DC. I'd surmise washers to be single speed, varied by transmissions or sheave; is that not the case? Clue I haven't unraveled is the extensive wire harness, apparently more than just timing of cycles.
