Results 1 to 10 of 11
Thread: Circular saw blade sharpening machine - GIF
    Circular saw blade sharpening machine.
    sharpening table saw blades at Quinn Saw
    Sharpening a huge drill bit - GIF
    dubbby (Mar 4, 2020), PJs (Nov 7, 2018), ranald (Nov 6, 2018), Seedtick (Nov 10, 2018)
    looks like it works great for a blace designed fo cutting paneling but I wonder how well it would work for blades with set in them for cross cut
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    handles blades much bigger than my makita 5" bench one which i hardly use now with TC blades.It can handle 9 1/4 " blades. Spose there are stones for them (TC): I just haven't looked.THe makita handles a little set but i never needed to try ones with heaps of set for really sappy woods like pinus elliotii.
    With that machine one would have to know the diameter & exact number of teeth And as Frank mentions the set?.
  5. The Following User Says Thank You to ranald For This Useful Post:
    PJs (Nov 7, 2018)
    I worked as a tool grinder for 17 years and I ran very similar machines. Mine were perhaps a bit more modern. The blade looks to me to be hollow ground on the sides (tapered) thus not needing set. It more than likely is used for cutting copper or aluminum. Just my opinion.
    LaVern
    8:38 source video:
  8. The Following 9 Users Say Thank You to Jon For This Useful Post:
    Andyt (Nov 22, 2018), Beserkleyboy (Nov 24, 2018), bigtrev8xl (Nov 22, 2018), emu roo (Jan 17, 2026), marksbug (Nov 25, 2018), PJs (Nov 24, 2018), ranald (Nov 22, 2018), Seedtick (Nov 21, 2018), Toolmaker51 (Nov 24, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nothing like old thumper motors, machines and Lederhosen...and finally we now know how they got that limb trimmer down!! I knew there was a use for kids...Hooray!
    Mark Twain
  10. The Following User Says Thank You to PJs For This Useful Post:
  11. #7
    Apr 2016
    those arefricking awesome!!!! I had a uncle that dided a few years ago of old age ,he worked in a big lumber/saw mill, he did all the saw sharpening till just before he retired and it was cheeper to stick new china blades on.
  12. The Following User Says Thank You to marksbug For This Useful Post:
  13. #8
    Quote Originally Posted by ranald View Post
    Silicon carbide [green wheels] usually grinds TC, but re-sharpening is more likely with diamond impregnated matrix. More expensive, but with a little care last a long, long time.
  14. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  15. #9
    That is where many in the been counting department have it wrong. especially those who cannot differentiate between bottom dollar cost versus longevity of service.
    they simply believe that change out times remain the same for top of the line or bottom of the line where they fail is in not accounting for the frequency of having to change out the cheap stuff. or the reduced quality of product at the near end of life blades.
    And no most times it is not worth re sharpening the cheap blades. the hardness is not there the coatings once worn off leave the blades to create higher friction and even warpege.
  16. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    Beserkleyboy (Nov 24, 2018), emu roo (Jan 17, 2026), Toolmaker51 (Nov 24, 2018)
  17. #10
    As I stated previously I ground tools for 17 years and in the first 4 years or so we were using what was called Semi-high speed steel blades. Thes blades did have a set put on them. How we did it was set the teeth before grinding giving a bit more than needed and for copper and aluminum we just ground them enough to clean them up straight across the top. On the blades that were needed to cross-cut wood the machine was set for half the number of teeth thus grinding every other tooth, and the wheel was either dropped or raised a certain amount to give the alternate bevel grind. After one side was done the blade would be indexed to start on a tooth of the other side. Most of the blades we ground were 12 to 14 inches in diameter.
  18. The Following 4 Users Say Thank You to lavern s For This Useful Post:
    emu roo (Jan 17, 2026), PJs (Nov 26, 2018), Toolmaker51 (Nov 24, 2018), Wildwilly (Mar 19, 2022)
