Clausing drill press 16"/ jacobs to MT tapper / fixing chuck issue / angular bearing
Ok instead of trying to modify this press for mill with angular bearing etc.
I wish to:
convert from Jacobs to MT2 (or other morse taper if better??) spindle
Fix chuck issue coming off (anything better then screw tap in chuck)
** so I can use bigger bits if wanted 1/2 - 5/8 - 3/4 bits)
I am putting on a 4 to 1 reduction pulley setup so I should have a ton of torque.. low speed will
be 80+ RPM.
Better lower bearing (angular??) not for milling - just better bearing ~
Make quall pull down "stiffer"??
Mill type fine tune quill pull down!
wanting a quality compound table. Looking at the mod table in mill converting thread.
anything else.
