Clean Paint Brush Mod
This paint brush mod will help keep the brush handle paint free keeping your hands cleaner and keep the brush from clogging making it easier to cleanup when the painting is over.
It's also convenient to hang your brush on the side of the can / container.
https://www.youtube.com/watch?v=cwS703Zpbnw
MATERIALS
- Paint brush
- Screw
Going to try that next time I am painting.
If you hang it on the side, isn’t the paint going to dry on the brush?
It is just like for taking a break, resting your hand or such, but not for hours, you are right.
Saw "paint brush mod", rolled eyes. But I had not seen this exact implementation; clever. I wonder if there's a Functional fixedness or similar such barrier that prevents us from inserting a screw into a tool. Also, something something magnets.
Similar concept, patented this past summer. Essentially a fancy version of tsbrownie's trick (plus the paintbrush handle in the patent is threaded to accept an extension pole; I need to think about that one). Click for full patent.
Paint Brush with Modified Handle
https://diqn32j8nouaz.cloudfront.net...dle_patent.jpg
Thanks tsbrownie! We've added your Paintbrush Modification to our Painting category,
as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-paintbrush-modification">
<img src="/uploads/221307/homemade-paintbrush-modification.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-paintbrush-modification">Paintbrush Modification</a>
<span> by <a href="http://www.homemadetools.net/builder/tsbrownie_3">tsbrownie</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/paintbrush'>paintbrush</a> </div>
</div>
</div>
</div>
The real benefit of a screw fixed in a brush this way is for the screw to be fixed at the balance point of the brush when it's laying flat, imagine a see saw.
This allows the brush to be rotated in a drill with the screw in the chuck and after cleaning the brush simply start the drill & rotate the brush for 20 seconds or so and the bristles will be dry, ready for the next use.
This can be done to assist cleaning the brush too. It really works.
