Results 1 to 8 of 8
Thread: Cleaning concrete by spraying gas on it - GIF
    Cleaning concrete by spraying gas on it? A joke? Slightly less dangerous because maybe it's diesel? Or just some internet-recorded stupidity?
    Automatic gas station fire extinguishers - video
    LPG station explodes in Cambodia - GIF
    Exploding gas station - video
    Gas station catches fire - GIF
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    Andyt (Nov 10, 2019), baja (Nov 5, 2019), rgsparber (Nov 4, 2019), Seedtick (Nov 4, 2019), shopandmath (Nov 3, 2019)
    At least he is not smoking while he is washing the concrete with an environmental contaminant
    capngeo's Avatar
    Jan 2019
    Just judging by the surface tension and viscosity.... I'm going with water
    Quote Originally Posted by capngeo View Post
    When was the last time you saw water come out of a gas or diesel pump nozzle?
    capngeo's Avatar
    Jan 2019
    Relax it’s a movie
  7. The Following 2 Users Say Thank You to capngeo For This Useful Post:
    cognitdiss (Nov 19, 2023), jimfols (Nov 5, 2019)
    Mar 2018
    Hoosiersmoker's Tools
    I have seen water pumps at gas stations but not since the early 80's. This is far too recent judging by the style of pump. At least he has a "Fire Watch" person behind the pump. But this fire watch is just there to watch the guy set himself on fire!
    I'm with capngeo - The liquid acts like water, not a fuel type. Also, you can hook those pumps up to tanks with anything you want in them.
  9. The Following User Says Thank You to Hoosiersmoker For This Useful Post:
  10. #7
    hemmjo's Tools
    Where do you see any surface tension in that video? If that was water, the "leading edge" of the liquid would not be so flat. You spray water from your hose on a concrete pad, the surface tension prevents the edges from flattening out until the concrete is wet. I do not see that anyplace in the video. Also the spray from the hose does not form into rounded droplets like water would.
  11. #8
    Supporting Member cognitdiss's Avatar
    Aug 2021
    SF Bay Area, CA
    It's diesel. Used to be a common way to wash down warehouse floors. Supposedly kept down the dust...
