Thread: Cleaning a griddle with a large ice block - GIF
    May 2024
    Cleaning a griddle with a large ice block.
    Capsizing iceberg - GIF
    Dry ice blasting machine - GIF
    Nomadic ice fishing and grilling - GIF
    Using ice to remove oil from cooking - GIF
    nova_robotics (Nov 15, 2024), thadrodgers (Nov 18, 2024)
    Mar 2018
    Hoosiersmoker's Tools
    I've seen dozens of "how to's" on cleaning a pan with cooked on food and I always remember growing up I learned when your stainless pan has burned on food from overcooking, first off, next time shut down the flame and don't burn your food and second, if you do get a burned on mess, heat the pan up smoking hot and carefully pour some cold water in then use a flat spatula and scrape the bottom of the pan. The steam releases all the food then suspends it in the water so the food doesn't burn back on. Or, if it's just a little food stuck, cook up some kind of tomato sauce. Your stainless pan will come out looking like new!
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
    Supporting Member odd one's Avatar
    Apr 2020
    WNC
    odd one's Tools
    If you try doing that on a flat top grill like a Blackstone, it will fold up like a taco. I temporarily warped mine just by throwing some frozen food on it once. That technique will only work without damage on one of the commercial griddles. Their cook tops are typically over an inch thick.
