Results 1 to 10 of 12
Thread: Cleaning shop floor with magnets - GIF
Hybrid View
    Cleaning shop floor with magnets.
    Magnetic window cleaning tool - GIF
    Magnetic doorstop - GIF
    Magnet paper for revealing location of magnets inside devices - GIF
  2. The Following 7 Users Say Thank You to Altair For This Useful Post:
    Alan Purdy (Jun 2, 2019), baja (Jun 1, 2019), KustomsbyKent (May 31, 2019), nova_robotics (Oct 29, 2022), rlm98253 (May 31, 2019), Seedtick (May 31, 2019), Slim-123 (Jun 1, 2019)
    Marion, Iowa
    metric_taper's Tools
    Nice idea,...
    Now I just need to find some ferromagnetic aluminum and brass.
  4. The Following 2 Users Say Thank You to metric_taper For This Useful Post:
    davesrepair (Jan 15, 2025), rdarrylb (Jan 17, 2025)
    loaders keep ballistic reports on all of their custom loads but I sometimes think pins screws and springs may go just as far and just as fast as some hot loads the problem is the trajectory is totally unpredictable
    looks like someone had been turning cast iron
    Marion, Iowa
    I have a magnet designed for this purpose of picking up iron swarf off the floor. The use of a plastic jug bottom is good, as removing fine material from the exposed magnet is a PITA.
    I machine plastics as well non ferromagnetic materials. That coupled with a rubber mat system with holes, makes for extra fun clean up. I typically hand pick up the larger swarf, then vacuum the dust and small turnings.
    My impression is that remains of flame cutting, grinding and sanding typical in weld shops.
  9. #7
    Would generally have larger chunks in the sweepings for flame cutting I'll yield tot the grinding though.
  10. #8
    Yes, chunks certainly in the pit below table and outside perimeter. I recall the oxidized dust piling in drifts everywhere else. It's like graphite, except abrasive and must be semi-spherical shape, because heavy parts slide nicely over it. Closest similar material is glass bead blast media, just as hard to sweep.
  11. #9
    But a really good Tennent vacuum will make short work of it.
  12. #10
    Dry Gulch, Tx
    Crusty's Tools
    When I was home gunsmithing I got one of those big retrieval magnets and hung it from paracord to swing it close to the floor. The first time I used it I found enough pins, springs, detents and fasteners to more than pay for the magnet.
