2 Attachment(s)
Using a Dog Leg Pointer and feeler gauges to Square up a Mill
After all these modifications I needed to square up the head on this tiny cnc. I couldn't use a DTi as it was just too big to fit. So I resorted back to the old fashioned method of using a dog-leg pointer and some feeler gauges.
Attachment 40736
The point was machined onto the bar before I then bent it to shape. The shape doesn't have to be perfect. It's made from 1/8" mild steel.
The length of the leg is around 1.25" and so the total span side to side is 2.5" - that combined with a 1 thou feeler gauge gets the head very square.
Attachment 40737
Just then rotate front to back and get the heights exactly the same, then do left to right.
You could use this method to square up the head on a milling machine or pillar drill.
