Results 1 to 7 of 7
Thread: CNC Router
    Apr 2017
    UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    editor@glue-it.com's Tools
    CNC Router
    Hi All,
    Building a small traction engine and I wanted to engrave the words around the smokebox door and for the main badge, so thought I would dip my toe into the world of CNC and bought a CNC engraver/router. OK it is very cheap and might not be up to the job, but this is a steep learning curve for me as only ever used manual machines before this point. I bought a Sain Smart CNC Router 3018-Pro.
    So, here is a video of the kit arriving and me assembling the machine. Will share more as I learn.
    Now I'm learning about G-Code, tool paths and how to set up the machine for different materials.
  2. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    Home-PC (07-25-2020)
    Apr 2017
    UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The only thing I've found lacking with the package are the table clamps, the extruded aluminium table is lovely. The T-nut is the head of a bolt that will damage the grooves over time and just don't seat that well. My thoughts are to make a set of brass T-nuts that engage with the underside of the groove, spread the load and don't over time dig into the surface.
  4. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    Apr 2017
    UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So, I've made T-nuts (a recurring theme here) for the Sain Smart Genmitsu 3018-Pro engraver/Router.
    Trouble was I didn't have the right size square bar...so I machined 3/4 inch diameter mild steel round bar into square:
    and eventually got to square
    and I ended up with six 14.4mm square nuts
    and they fit superb, will have to create a quick drawing for others to use
    The drawings might not happen, hence dimensions: The T-nuts are 14.4mm across, the square nut is 6mm high and has an 8mm diameter boss protruding 2mm from the top. The nut is threaded 6x1mm. They are threaded the whole way through the nut.
  6. The Following 7 Users Say Thank You to editor@glue-it.com For This Useful Post:
    Altair (07-29-2020), Carnel (07-25-2020), Home-PC (07-25-2020), Jon (07-24-2020), old_toolmaker (07-25-2020), Rocconet (07-25-2020), Tonyg (07-25-2020)
    Altair's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks editor at glue-it.com! We've added your CNC Router Table Clamps to our CNC category,
    as well as to your builder page: editor at glue-it.com's Homemade Tools. Your receipt:
  8. The Following User Says Thank You to Altair For This Useful Post:
    editor@glue-it.com (09-01-2020)
    Apr 2017
    UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Spent some time yesterday using different cutting bits to see if I could engrave brass
    At the moment I don't have a solution that allows me to engrave brass with the Genmitsu 3018-Pro. I might try some smaller bits, but spindle stiffness and runout appears to be a fundamental weakness.
  10. #6
    Apr 2017
    UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My workshop is really small
    so I made a box for the CNC so it can tuck under the workbench safely
    just lift the cover, plug it in and it works.
  11. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    Altair (08-14-2020)
  12. #7
    Altair's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks editor at glue-it.com! We've added your CNC Router Storage Box to our Storage and Organization category,
    Post your reply!
    eBooks for Supporters
  13. The Following User Says Thank You to Altair For This Useful Post:
