Thread: Compressed air elevator - photo
    Altair's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  2. #2
    Unkle Fuzzy's Avatar
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Actually those units use a fractional horsepower vacuum blower. In the event of a motor failure they slowly settle to the bottom floor.
    The motive system is at the top allowing retrofit into existing buildings without excavating a pit under the shaft.
    I looked at them about 8 years ago for a friend who is disabled.
  3. The Following 2 Users Say Thank You to Unkle Fuzzy For This Useful Post:
    suther51 (07-09-2020), Toolmaker51 (07-10-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Back in the 1970s I had a workshop on a first floor. There was an old compressed air lift big enough for a van. It used to leak a bit passed the ram seals so it took a while to pump up.
    One day we had a visit by the H&S bloke. Just as he was leaving he spied the compressor and then the lift. He condemned it immediately and made me remove a section of the air line to the lift. Later I put quick release fitting on that line (2" water pipe) so that it was mostly disconnected to satisfy any follow up visits. I would connect it whenever we had a motorcycle to bring up or take back down, then remove it when done. I continued for another 5 years like that, until I moved workshops.
    It was far safer than the only alternative way, which was to push and pull the bikes up and downs a flight of narrow stairs with a 180 bend in the middle.
    Post your reply!
    eBooks for Supporters
  5. The Following User Says Thank You to tonyfoale For This Useful Post:
    high-side (07-13-2020)
