Results 1 to 9 of 9
Thread: Concrete mixer cheaper in Brazil
    Supporting Member ederangelo's Avatar
    May 2015
    Macae , Rio de Janeiro, Brazil
    ederangelo's Tools
    tag in portuguese
    betoneira caseira
    link https://www.youtube.com/results?sear...oneira+caseira
    here in Russia
  2. The Following 3 Users Say Thank You to ederangelo For This Useful Post:
    DIYer (Sep 16, 2017), Seedtick (Sep 16, 2017), Y-geo (Sep 16, 2017)
    it gets the job done and that is what counts. actually looks to be a pretty good rig simplicity at its finest.
    Thanks ederangelo! We've added your Concrete Mixer to our Miscellaneous category,
    as well as to your builder page: ederangelo's Homemade Tools. Your receipt:
    Supporting Member Y-geo's Avatar
    Aug 2017
    west london
    Y-geo's Tools
    hi,
    That brings back memories of a boiled sweet de-flashing drum i built about 1980 with a very shallow angled washing machine drum on 4 casters inverted one of which was driven by a chain from the conveyer that came from the sweet punch machine.
    The press processing the hot sugar rope left a very fine flash of sugar that when it was cooled was EXTREMELY sharp, the individual sweet was then transported on a chain mail conveyor belt with cooling air blast. The sweets were then dropped into my washing machine drum that "de-burred" the sweet by tumbling them.
    S & F
    Y-Geo
    Quote Originally Posted by Y-geo View Post
    hi,
    Hard rock candy cool
  7. The Following User Says Thank You to Frank S For This Useful Post:
    Y-geo (Sep 17, 2017)
    Marion, Iowa
    metric_taper's Tools
    I was going to pour some repair patches of concrete this morning. But instead I spent the day repairing a cheap import mixer (says 3.5 Cu.ft., but really only 1cu.ft.). I used it 10 years ago to mix mason mortar, to lay up concrete block for my house addition.
    Well it sat these past 10 years under an overhang. The dual ball bearing drum support froze up. So after much dis-assembly, and a can of penetrating oil, it's working. I installed a zerk to fill the sealed from access space with grease.
    The concrete repair is because of a ground hog (marmot, wood chuck, whistlepig) that was able to dig under the door, and then a hole down in the back of the shed. It filled 4 wheel barrows of earth inside.
    I really dislike these critters, they undermine any concrete slab buildings around here.
    Concrete mixer cheaper in Brazil-2017-09-16-cement-mixer-repair-004-edit.jpg
  9. The Following User Says Thank You to metric_taper For This Useful Post:
  10. #7
    Aug 2017
    a lot better than a shovel and wheelbarrow
  11. #8
    Marion, Iowa
    I stored it with the bearing up as it freezes here. But I didn't think about a small amount of wind blown snow melt over 10 years, and no weep holes to let it out, that would damage the bearings. There should have been a zerk fitting for grease from day one.
    And so true, it is better then mixing by hand. For as cheap as it is, it works. And it has an over current circuit breaker to prevent motor burn out.
  12. #9
    Likle has been said ii beats mixing in a wheel barrow, I've seen a lot of guys just mix right on the ground at the edge of their sand pile
