Anyone on here ever use a manual slack adjuster for continuous operation as a speed reducer?
Just wondering how one would stand up.
Also I would like to know what the ratio is.
Attachment 40125
Attachment 40125
They are not exactly made to be used as a speed reducer there are no bearings inside of them just bushings
If you wanted to use one as reduction gear for something like a weld positioner they work great and last quite a long time if you keep the worm and gear well greased. You can turn them with a drill motor at low RPM intermittently.
I wouldn't want to use on as a speed reducer without remanufacturing it with bearings and a proper housing.
I turned 1 into a torque multiplier once, before I bought a real one But I don't remember the ratio though
in one of the Australian metalwork forums, there is a guy who used one to make the gearbox of a cold cut saw...he used Holden wheel bearings for the main spindle, and set the gears in a "closed" submerged oil gearbox so they run in oil continuously. unfortunately I cannot provide a name or reference since it's been a while since I read about it.
They work good to rotate engines on engine stand. Will rotate a diesel engine easily and hold.
Learn something new every day. I have been adjusting these things for years and never given a thought to the above uses.
Agreed.
Having never worked on large truck air brake systems I had no idea what a manual slack adjuster was so I googled it. This is an interesting bit of info to file away, I could see it being a handy gizmo to repurpose things you might be building. They are amazingly inexpensive considering what they are.
Thanks for educating me, I learned my first new thing for today!
