I understand, from having built a number of large flying scale model aircraft and taken engineering classes covering such designs, the necessity of both light weight and flexibility in wing structures (which wind turbine blades essentially are). But I was surprised how flimsy those blades seemed to be. A long while ago, I watched a 777 (if I remember correctly) static wing deflection test, and they bent that thing nearly 30 feet before it failed! I know these were different sorts of loads from that, but the blade on the ship side appeared to go limp like a noodle for its entire length when it struck.
