Cross Slide Mod 9x20 Lathe. Added new turning wheel to the cross slide for faster lead screw turning.
Attachment 2841
Attachment 2841
Thanks Captainleeward! I've added your Lathe Cross Slide Modification to our Lathes category, as well as to your builder page: Captainleeward's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="/lathe-cross-slide-modification"><img src="/uploads/108597/lathe-cross-slide-modification.jpeg" alt="Lathe Cross Slide Modification" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="/lathe-cross-slide-modification">Lathe Cross Slide Modification</a> <span> by <a href="/builder/captainleeward">Captainleeward</a></span> </div> <div class="tags"> tags: <a href="/tag/lathe">lathe</a>, <a href="/tag/wheel">wheel</a>, <a href="/tag/modification">modification</a>, <a href="/tag/cross-slide">cross slide</a> </div> </div> </div> </div>
That new wheel is larger by how much, captain? Good job!
Hi DIYer, its the same as the one below in fact it is the same wheel modded to fit.
