Coupon code for 20% off membership: SPRING20
Thread: Custom plugs for drop-in anchors
    earz's Avatar
    May 2014
    earz's Tools
    I recently installed some drop-in anchors in my garage floor to bolt my manual tire changer down. I wanted a way to keep dirt out of the threads when the tire changer was put away, so I 3D modeled and printed some custom plugs.
    Hope you guys find it useful.
    Save 20% on Membership
  2. The Following 7 Users Say Thank You to earz For This Useful Post:
    BuffaloJohn (Jan 27, 2023), butlerandrew (Jan 28, 2023), Jon (Jan 26, 2023), kboy0076 (Jan 31, 2023), metric_taper (Jan 29, 2023), Scotty1 (Jan 29, 2023), thevillageinn (Jan 28, 2023)
    Thanks earz! We've added your Drop-In Anchor Plugs to our Miscellaneous category,
    as well as to your builder page: earz's Homemade Tools. Your receipt:
    Marion, Iowa
    metric_taper's Tools
    I did the same thing for my harbor freight tire changer, but mine is outdoors on the slab under a car port, which is exposed to rain and snow, and salt from my car. I used 1/2-13 bolts that I machined the hex down a bit to reduce the trip hazard, and innertube rubber washer gasket as a seal to keep water out under a steel washer. I also stuck lots of grease to displace any water that does leak in. So far this has worked to prevent the bolts from corroding in place.
    I don't have a 3D printer, but I like this solution, that has a much lower profile, and grease should not dissolve the plastic.
