Results 1 to 4 of 4
Thread: Cutting coins
    Cutting coins
    Cut coin jewelry seems to be rising in popularity. Though rumored to be illegal, it's probably not, because the coins are not being altered with fraudulent intent: U.S.C. Title 18, Part I, Chapter 17, Sec. 331: Mutilation, diminution, and falsification of coins
    One common way to do it is by hand with a jeweler's saw. A few options:
    You can cut out the negative space, enhancing the main image, like this:
    You can also cut any new shape out of coin, essentially ignoring the existing imagery on the coin:
    Coins can be cut for an interlocking effect, both for shared jewelry and mini jigsaw puzzles.
    I like this concept of cutting out the heads, which can later be used as jewelry or ornamentation.
    Pendants and keychains are common, with nicer coins made into money clips on the high end.
    This video shows the process, and can safely be speeded up to 2X speed.
  2. The Following 2 Users Say Thank You to Jon For This Useful Post:
    iffee100 (Dec 11, 2016), PJs (Dec 11, 2016)
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    would be nice to know what equipment you use to hold and cut out the material.
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
    Oct 2012
    Very nice, beautiful touch.
    Nelson
    I believe that they're press-fitted into a basic coin-shaped cutout like what you see in the video. Then, they drill holes in the coin, and initially thread the end of a jeweler's saw through the holes to start the cuts. I've also seen it done with a scroll saw, but I'm not sure that can match doing it by hand with a jeweler's saw.
    Magnification might be helpful here. I suspect it's easy to screw up the cut, but if you're working with common coins, the errors are cheap.
