Results 1 to 6 of 6
Thread: CUTTING SCREWS WITHOUT DAMAGING THE THREAD!
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
  2. The Following 7 Users Say Thank You to machining 4 all For This Useful Post:
    alan clare (May 10, 2021), johncg (May 10, 2021), Jon (May 5, 2021), NortonDommi (May 5, 2021), Ralphxyz (May 4, 2021), rarmintrout (May 4, 2021), Scotsman Hosie (May 8, 2021)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    You can also do this by cutting a nut radially. The flats fit nicely in a 3 jaw chuck.
    Rick
    Rick
  4. The Following 4 Users Say Thank You to rgsparber For This Useful Post:
    NortonDommi (May 5, 2021), Ralphxyz (May 4, 2021), rarmintrout (May 4, 2021), Saltfever (May 6, 2021)
    May 2020
    I suggest a round device as I did, as it is easily adaptable in any situation (drill chuck, spring collet, lathe chuck 3 jaws, lathe chuck 4 jaws, etc). You can't get a perfect center with hex nuts!
  6. The Following User Says Thank You to machining 4 all For This Useful Post:
    greenie (May 1, 2021)
    Thanks machining 4 all! We've added your Screw Cutting Fixture to our Lathe Accessories category,
    as well as to your builder page: machining 4 all's Homemade Tools. Your receipt:
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Quote Originally Posted by machining 4 all View Post
    You can get surprisingly close with two spaced apart in the jaws. Bit hard in the 4-jaw though.
    May 2020
    NortonDommi, this device works perfectly for a plate with dependent jaws, not with independent jaws... Why would I use a giant plate to cut such a small screw, is not true? Thanks for the comment and interest!
