Results 1 to 4 of 4
Thread: Cutting Sheet Metal With a Paper Cutter
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    I have an old fashioned Olsen paper cutter I retrieved from a dumpster about 35 years ago. It has a wood base and is quite sturdy. I have used it regularly to cut sheet metal up to about .020" thick. It will cut about 12" easily, and if a longer cut is needed, I just go at it from both sides of the sheet.
    Since you can make partial cuts, it has the same versatility as hand shears, but without the curling. Anything thicker than .020" gets tough on the cutter.
    A "Premier" 18" or 24" paper cutter, available at globalindustrial.com, would probably get the job done too.
    Cutting Sheet Metal With a Paper Cutter-img_9187.jpg Cutting Sheet Metal With a Paper Cutter-img_9194.jpg Cutting Sheet Metal With a Paper Cutter-img_9197.jpg Cutting Sheet Metal With a Paper Cutter-img_9199.jpg Cutting Sheet Metal With a Paper Cutter-img_9200.jpg
  2. The Following 5 Users Say Thank You to tmate3 For This Useful Post:
    Baddog (Feb 16, 2021), Jon (Feb 17, 2021), Priemsy (Feb 21, 2021), raynjer (Feb 16, 2021), rlm98253 (Feb 15, 2021)
    Thanks tmate3! We've added your Sheetmetal Cutter to our Metalworking category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
    Baddog's Avatar
    Jun 2017
    Baddog's Tools
    I have a Milton-Bradley (who knew?) Popular 5215. Not as beefy as yours, but cuts card stock and very thin aluminum quite well. Not sure I want to use it on steel though.
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    Been using my old paper cutter for sheet aluminum up to 0.032" for quite a while. The main problem is holding it down well enough to not make a curved cut.
    Poor man's sheet metal cutter!
    Paul A.
