48 hours only - save 20% on membership with code: 1776
Results 1 to 7 of 7
Thread: Decorative LED cube - GIF
    Altair's Avatar
    Use coupon: 1776
    Dimsa (May 17, 2022), durrelltn (May 21, 2022), nova_robotics (May 18, 2022)
    Sep 2018
    nova_robotics's Tools
    16x16x16 LED cube? So 4096 lit elements, which are RGB, so 16384 LEDs. I'm not seeing a lot of wires. Are these digitally addressable in some way, or maybe some really complex charlieplexing going on? I'm sure it's digital because that would be easy, but really I hope it's charlieplexing.
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    They are regular RGB LEDs that are wired together into a matrix via their leads. If you look closely, there are 16 panels of LEDs that we see end on for much of the video. To address an individual LED they use the panel, row, and column numbers. I have wanted to build one of these for years, but it's terribly fussy building all the panels. Most folks use various forms and templates to get the LED leads bent just right and the LEDs all evenly spaced. Oh, and the silvery LED leads and solder help disguise all the connections that are there.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
    Sep 2018
    Quote Originally Posted by schuylergrace View Post
    I'm not sure about that. Pause the video between the 0 and 3 second mark. I don't see any horizontal wires at all. If you look close there are only vertical wires on the clear plastic. Also if you were scanning that many RGB LEDs it would be extremely difficult to PWM all the lights correctly to get different colors.
    I think it's something like a bunch of WS2812B or SK9822 strips adhered to acrylic or polycarbonate sheets. If I were building it that's what I'd do. You can just peel the adhesive backer off the LED strips and stick them to the plastic. Everything's done for you and you don't have to run wires. Then you only need common power and two data wires off the bottom of each strip (in the base). It's still a bunch of wiring, but it's not 4096 wires in a full blown matrix.
    Edit: For a matrix you'd need 12288 wires, not 4096. Whoopsie. For addressable strips you'd need 512 wires and each strip would be connected to a common power and ground.
    Sep 2020
    Mesa, Arizona
    There aren't any horizontal wires from that angle. The panels are each standalone, so each panel is a flat matrix of LEDs with interconnections between the panels hidden in the base. Here's a video showing how that one was made. It may not be the simplest way, but it worked. And I've been thinking about using very small form factor addressable LEDs to make one of these with thin wires making the interconnects, instead of tape. It would still be a nightmare to build, but less work than what he went through.
  7. The Following 2 Users Say Thank You to schuylergrace For This Useful Post:
    Altair (May 29, 2022), nova_robotics (May 19, 2022)
    Sep 2018
    Quite the build. Very impressive. I thought it was adhered to plastic sheets but nope, the wires and LEDs are free standing. Amazing. The LEDs are addressable though. Check out 4:33 in the video. Did you catch a part number for the LEDs in that video? I didn't see anything. Each one gets power, ground, data in and data out. He's using a Teensy 4.0 and 3 data pins are used to drive 128 LEDs.
  9. The Following User Says Thank You to nova_robotics For This Useful Post:
    schuylergrace (May 19, 2022)
  10. #7
    Sep 2020
    Mesa, Arizona
    It has been a while since I last watched this video, so I forgot he was using addressable LEDs (WS2812s). There was another video like this one, where they guy was using common cathode (or anode--I forget which) RGB LEDs to do the same thing, but he had to address them by their matrix location, not their order in the chain. I hope he found a good source for bulk LEDs, though, because by my calculations, he has around $3,000 in LEDs, alone, in this project! Here's a link to LEDs like the ones he used:
    https://www.sparkfun.com/products/12986
  11. The Following User Says Thank You to schuylergrace For This Useful Post:
