Results 1 to 8 of 8
Thread: Demolition of the old eastbound I-74 bridge on June 18, 2023
    Supporting Member jimfols's Avatar
    Sep 2015
    Ontario Calif USA
    FF to 1:03
    Jim
  2. The Following 3 Users Say Thank You to jimfols For This Useful Post:
    Altair (Jun 25, 2023), nova_robotics (Jun 23, 2023), Ralphxyz (Jun 24, 2023)
    nova_robotics's Tools
    I can't believe they demolished that structure over a waterway. Any time I've been on a project near water you're not allowed to pour your coffee on the ground, just in case some seeps into the water and gives a catfish an erection. The access looks really good from the water. Why didn't they go in with crane barges and haul sections off for scrap? Now they're going to need to hire divers to rig the damaged sections underwater and try to fish them out that way. That cannot possibly be more cost effective. They must have had a very compelling reason to use explosives.
  4. The Following User Says Thank You to nova_robotics For This Useful Post:
    jimfols (Jun 23, 2023)
    PDXsparky's Avatar
    Nov 2018
    Well I feel ripped off, they only did half of the job.
    Jul 2019
    Taxpayers clapping while watching their dollars go up in smoke! Seems that the deck was removed before exploding of the main supports. I wonder why it all wasn't removed the way that the deck was?
    To me it makes as much sense as pockets in your underwear!
    Quote Originally Posted by Wildwilly View Post
    The suspension cables of this type of bridge are essentially strung from anchor point over the support towers and down to the second anchor point 1 strand at a time by sending a tugging rover back and forth across the span until a huge bundle of strands complete the suspension cables then the bundles are clad with a cover installed in sections adding the drop lines at the pre-determined intervals. Once completed the deck is added. Removing such a bridge is done in reverse order the deck can be lowered to barges and floated away in reasonable safety. Trying to remove the suspension cables in reverse order would be quite another matter. Next to if not completely impossible to be done both safely and economically. due to the many years of everything being under extreme stresses plus factoring in the deterioration of the components themselves. This is why explosive charges would be the wisest choice. Once in the water it would be as simple as grappling, lift, cut into sections and haul away
  8. The Following User Says Thank You to Frank S For This Useful Post:
    jimfols (Jun 25, 2023)
    Hoosiersmoker's Tools
    Also... a two minute video for 15 seconds of actual demolition?
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
    Quote Originally Posted by Hoosiersmoker View Post
    It builds suspense. Get it? Get it? A suspension bridge? Suspense? I'm here all day, folks.
  11. The Following User Says Thank You to nova_robotics For This Useful Post:
    Hoosiersmoker (Jun 27, 2023)
  12. #8
    I see what you did there!
    - Muhammad Ali
