Results 1 to 4 of 4
Thread: Dent pulling suction cups - GIF
Hybrid View
    Dent pulling suction cups.
    Spot weld dent puller - GIF
    Electromagnetic car dent removal - GIF
    Soccer fans bang out car dent - GIF
  2. The Following 7 Users Say Thank You to Altair For This Useful Post:
    emu roo (May 25, 2026), kboy0076 (May 4, 2021), mwmkravchenko (May 1, 2021), NortonDommi (May 3, 2021), Rangi (May 1, 2021), rlm98253 (May 1, 2021), tuchie (Jul 7, 2024)
    Elizabeth Greene's Tools
    Most paintless dent repair doesn't use suction cups, but instead it's hot glue. There's a little foot that they glue in place and then they can pull or pop that.
    The kits are cheap if you want to learn how to do it. It's satisfying methodical work.
  4. The Following User Says Thank You to Elizabeth Greene For This Useful Post:
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Quote Originally Posted by Elizabeth Greene View Post
    Actually the Paintless Dent Removal system started with vacuum cups, there were air venturi powered suction cups that could be fitted to a slide hammer or set on a dent for use with a puller. This progressed to using hot glue and now there is a Urethane product,(cold glue), that is reusable but it is NOT cheap.
    https://denttime.com/store/#!/Glexo-...229/category=0
    The hot glue system is widely used with special glues for different temperatures and pad sizes.
    Still an amazing process.
  6. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    cagiva (May 11, 2021), emu roo (May 25, 2026)
    Mar 2018
    Hoosiersmoker's Tools
    Looks like a before and after. The last shot is the before, the dent was made after, then attempted to pull the dent. Otherwise why change the camera angle?
  8. The Following User Says Thank You to Hoosiersmoker For This Useful Post:
