Coupon code for 40% off membership: SUMMER24
Results 1 to 6 of 6
Thread: Deploying an aircraft emergency slide - GIF
  2. The Following 4 Users Say Thank You to ToolTalkBot For This Useful Post:
    albertq (May 21, 2024), KustomsbyKent (May 21, 2024), nova_robotics (May 21, 2024), Ralphxyz (May 21, 2024)
    Perth Ontario Canada
    That must be some fun to pack back up!
    Mark
  4. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    Frank S (May 21, 2024)
    May 2015
    Tasmania, Australia
    Bony's Tools
    But it deploys right over the red hot engine!
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by Bony View Post
    yes - but if it deploys on dry land, people are on and off the slide in a few minutes, and the cowling will protect the slide long enough... and if it the slide deploys in water, the red hot engine isn't red hot anymore.
    May 2015
    Tasmania, Australia
    Bony's Tools
    Mmm, but won't the heat deflate it. Or have I missed something?
    hemmjo's Tools
    There is very little heat radiated from the sides of a modern jet liner engine. Modern turbo fan designs pump huge volumes of air through external ducts to add thrust to the exhaust. An heat that is lost to the sides is lost thrust. All of the heat is "blown" out the back.
    Remember there can't be so much heat escaping from the sides because the engines are bolted to the fuel tanks!!
