I originally posted this as a metal lathe mystery project.
https://www.youtube.com/watch?v=l0I8szpZyDE
Cheers Rob
Cheers Rob
Nice addition to your precision tools accessories. Also thanks for the visual tip on using the tailstock feed for the fine feed during the lathe milling operation.
Hi Paul,
I wondered how many would pick up on that - you're the first.
While it allows precision advancement of the carriage, it also has several other important benefits:
- It prevents the mill slide from canting back, as you apply all pressure at the centre spindle line of the lathe.
- It reduces chatter as the mill slide is braced at the back/centre line.
Advancing the saddle with the carriage hand wheel is not a good idea, for all of the above reasons.
Cheers Rob
Thanks xynudu! We've added your Depth Measuring Caliper Base to our Measuring and Marking category, as well as to your builder page: xynudu's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/depth-measuring-caliper-base"><img src="https://www.homemadetools.net/uploads/237666/homemade-depth-measuring-caliper-base.jpeg" /></a></div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/depth-measuring-caliper-base">Depth Measuring Caliper Base</a> <span> by <a href="/builder/xynudu">xynudu</a></span> </div> <div class="tags">tags: <a href="http://www.homemadetools.net/tag/caliper">caliper</a>, <a href="http://www.homemadetools.net/tag/base">base</a>, <a href="http://www.homemadetools.net/tag/mount">mount</a></div> </div> </div> </div>
Hi Rob,
A neat project and a very well-done video. Your Depth Measuring Caliper Base is our 'Best Documented Build' for February, 2016!
You'll be receiving a $35 online gift card.
Just send me your email address (via PM) and we'll get things processed directly.
Congrats!
Ken
