Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 51 to 53 of 53
Thread: Dial Indicator Attachment
  1. #51
    Marion, Iowa
    metric_taper's Tools
    Quote Originally Posted by rossbotics View Post
    This is a dial indicator attachment I designed for use in the milling machine for indicating small holes and tramming the mill, after a few hours horsing around in CAD I came up with this tool.
    Attachment 17856
    So I just procured the O-1 tool steel for the Swing arm. I stock drill rod, but no flat bar tool steel.
    I did not spend the day in the shop, as I dealt with noxious weeds on the adjoining property. Stinging Nettle, cocklebur, and many other weed species. I did have to repair the lawn mower that I use as a brush hog. And it required a lathe to make a new muffler bolt.
    Dial Indicator Attachment-2017-05-29-muffler-bolts-006.jpgDial Indicator Attachment-2017-05-29-muffler-bolts-002.jpg The bolt stock is a 3/8"x3" bolt turned down as a shoulder bolt to 1/4-20 threads. So it was a good memorial day, and I'm pooped pushing the mower over 3 foot high weeds.
    And once again I high jacked the tread with the early post of wire wheels which caused a diversion to shop safety. But I hope to be able to post photos of the finished dial indicator holder, but it will probably be weeks with all the other tasks that summer brings.
    Steve
  2. #52
    Briefly, gloves create problems in two main instances; with cutting edge of rotating tools pointed out earlier and gaps twixt rotating objects/ solid surfaces, as stated by NortonDommi.
    Most won't object to gloves protecting against open friction.
  3. #53
    Dec 2016
    Ralphxyz's Tools
    Wow, thanks for posting. Just what I need another project but definitely on my list!
    Ralph
    Download plans for dros.
