They're brazing in this video, but I think the methodology might also be sound for some select welding repairs as well. They drill, tap then install screws in the area to be repaired. The screw material is weldable while the base material is not. If you did this to cast iron parts, you may be able to perform a weld repair in certain circumstances.
https://www.youtube.com/watch?v=Nd6m-FdoheQ
