Results 1 to 6 of 6
Thread: Disk Sander 200 мм + Bench Grinder Nestor Makhno
    Supporting Member h7eh7e's Avatar
    Jun 2017
    Ukraine. Krivoy Rog.
    h7eh7e's Tools
    Good afternoon. I will show you one of my works. This is Disk Sander 200 mm Nestor Makhno.
    Disk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-028.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-053.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-065.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-071.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-077.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-083.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-200-bench-grinder-nestor-makhno-_-089.jpgClick image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 028.jpg
ID:	34257Click image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 053.jpg
ID:	34258Click image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 065.jpg
ID:	34259Click image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 071.jpg
ID:	34260Click image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 077.jpg
ID:	34261Click image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 083.jpg
ID:	34262Click image for larger version.
Name:	Disk Sander 200 мм  + Bench Grinder Nestor Makhno   _ 089.jpg
  2. The Following 3 Users Say Thank You to h7eh7e For This Useful Post:
    cfpcorp (Apr 2, 2020), Jon (Apr 2, 2020), Paul Jones (Apr 6, 2020)
    Jun 2017
    h7eh7e's Tools
    Here you can see the machine at work.
    Jun 2017
    h7eh7e's Tools
    Bench Grinder+ Disk Sander Nestor Makhno
    Bench Grinder+ Disk Sander Nestor Makhno.
    Disk Sander 180 mm. Bench Grinder 200 mm.
    Disk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_071.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_126.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_120.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_113.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_107.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_032.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_016.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_096.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_083.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_073.jpgDisk Sander 200 мм  + Bench Grinder Nestor Makhno-disk-sander-bench-grinder-nestor-makhno-201-_128.jpg
    Thanks h7eh7e! We've added your Disc Sander to our Grinding category,
    as well as to your builder page: h7eh7e's Homemade Tools. Your receipt:
    Jun 2017
    h7eh7e's Tools
    VIDEO.
    Jan 2020
    Fantastic machines you build; thank you for sharing your work with us.
    Casey
