Get 500+ homemade tool plans, tool build guides, ebooks, and much more.
Results 1 to 10 of 15
Thread: Dividing Head (indexer) Version 2.0
    Machining 4 ALL
    machining 4 all's Avatar
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    machining 4 all's Tools
    45 Best Harbor Freight Tool Modifications
  2. The Following 9 Users Say Thank You to machining 4 all For This Useful Post:
    Big-Pete (05-19-2020), Carnel (05-19-2020), DakotaDave (05-18-2020), FEM2008 (05-18-2020), Jon (05-19-2020), Karl_H (05-18-2020), mwmkravchenko (05-18-2020), Paul Jones (05-26-2020), Saltfever (05-29-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    500+ Homemade Tool Plans
    Thanks machining 4 all! We've added your Dividing Head to our Machining category,
    as well as to your builder page: machining 4 all's Homemade Tools. Your receipt:
    Forge Build Guide
    machining 4 all (05-31-2020)
    Aug 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wizard69's Tools
    Quote Originally Posted by machining 4 all View Post
    That is one nice looking indexer!
  6. The Following User Says Thank You to wizard69 For This Useful Post:
    Machining 4 ALL
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the comment!
    Sep 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello.I am thinking of building some the same.
    What is the Torque (NM) of stepper motor you used
  9. The Following User Says Thank You to LeighS For This Useful Post:
  10. #6
    Machining 4 ALL
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello LeighS! Below is a specification of the stepper motor used:
    - Nema 23 200 PPR
    - Holding torque: 9.8 kg.cm (0.9 N.m)
    - Rated current: 1.8 A
    - Recommended voltage: 24-48 V
  11. #7
    May 2014
    Del Mar, California
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Paul Jones's Tools
    Very nice design and build. What are the specs for the two rear gears? Did you make these or sourced the gears from a supplier like Boston Gear?
  12. The Following User Says Thank You to Paul Jones For This Useful Post:
  13. #8
    Machining 4 ALL
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the comment Paul Jones! I made the gears myself. The larger gear has 84 teeth and the smaller gear has 21 teeth. I used a 1.25 mm metric module.
  14. The Following User Says Thank You to machining 4 all For This Useful Post:
    Paul Jones (05-28-2020)
  15. #9
    Apr 2012
    NorCal
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Very nice. Could you describe your bearings and how, of if, you preload them.
  16. The Following User Says Thank You to Saltfever For This Useful Post:
  17. #10
    Machining 4 ALL
    May 2020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the comment Saltfever!The bearings used are 6006 2Z number. Preload equal to 37 N (3.8 kgf) carried out through the weight of the plate and the spindle (satisfactory value for a maximum rotation equal to 500 rpm).
  18. The Following User Says Thank You to machining 4 all For This Useful Post:
    Paul Jones (05-30-2020)
