Results 1 to 10 of 10
Thread: DIY high speed sensitive drill press.
    A regular drill press spins too slowly for very small drill bits and parasitic forces reduce the "feel" for what the drill bit is doing. Both of these factors often contribute in a major way to broken small drills.
    For some time I have been thinking about making a sensitive high speed drill press using the high speed spindle that I use only occasionally on my mill and also lathe. A few days ago a drill press meant for pistol drills came up on a local classified for sale list. It was of higher quality than most items of that genre that I have seen, and I bought it for only 20 euros.
    DIY high speed sensitive drill press.-small-01.jpg Click images for full size versions.
    Only a minimum of work was required to mount the spindle on it but a little more work was required to make and fit a counter-weighted balance system.
    DIY high speed sensitive drill press.-small-04a.jpg DIY high speed sensitive drill press.-small-07.jpg
    I have made a 20 minute video which explains the conversion as well as demonstrating the requirements of a sensitive drill and showing some tests of how I checked the success of my efforts.
    Don't forget to like and share the video, and subscribe to my channel for news of new videos.
  2. The Following 21 Users Say Thank You to tonyfoale For This Useful Post:
    Andrepetrus@04 (Mar 7, 2019), emu roo (Nov 28, 2022), Grego009 (Apr 22, 2021), hotdog0627 (Apr 22, 2021), johncg (Apr 22, 2021), Jon (Mar 8, 2019), mr mikey (Jun 21, 2025), olderdan (Mar 6, 2019), oldpastit (Mar 7, 2019), Paul Jones (Mar 7, 2019), philippacificnw (Jun 22, 2025), rgsparber (Mar 6, 2019), rlm98253 (Mar 6, 2019), Scotsman Hosie (Mar 10, 2019), Seedtick (Mar 6, 2019), swk (Mar 22, 2022), terence b (Jun 21, 2025), threesixesinarow (Jan 10, 2020), Tonyg (Mar 23, 2022), uv8452 (Jun 21, 2025), volodar (Mar 8, 2019)
    olderdan's Tools
    Great video as usual and in depth analysis of requirements. I am in the process of making a high speed drilling attachment for my tailstock for the same reasons as I have a low speed lathe. Up to my neck in house renovation at the moment but I will post when I finish it.
    Regards
    Olderdan
  4. The Following 2 Users Say Thank You to olderdan For This Useful Post:
    Paul Jones (Mar 7, 2019), tonyfoale (Mar 6, 2019)
    Regards
    Olderdan
    Looking forward to seeing it.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Tony,
    Wonderful design and explanation!
    Thanks,
    Rick
    Rick
  7. The Following 2 Users Say Thank You to rgsparber For This Useful Post:
    tonyfoale (Mar 7, 2019), uv8452 (Jun 21, 2025)
    Here is the finishing touch. Most things to get drilled on this will be small and hand held, the original large T-slots in the base were a nuisance so I added a flat plate. This has made it more convenient to use.
    DIY high speed sensitive drill press.-small-08.jpg click for full size image.
  9. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    swk (Mar 22, 2022), uv8452 (Jun 21, 2025)
  10. #6
    Thanks tonyfoale! We've added your Sensitive Drill Press to our Drilling and Drill Presses category,
  11. #7
    Thanks tonyfoale! We've added your High Speed Drill Table to our Drilling and Drill Presses category,
  12. #8
    Aug 2016
    wizard69's Tools
    Nice build Tony!
    That drill press support is what I would call a lucky fine. I have not see anything of similar quality.
ID:	28622 click for full size image.
  13. #9
    Quote Originally Posted by wizard69 View Post
    Nice build Tony!
    I couldn't agree more.
  14. #10
    I can't believe that this post was over six years ago. In that time the drill has proven its usefulness countless times. Mostly it it used with sub 1 mm bits and I can report that I have never broken a bit with it. The sensitive feel is great for small drills.
    Download plans for drilling and drill presses.
