MAKING METAL/WOOD SCRIBERS AND GRINDER HOLDER!!!
https://www.youtube.com/watch?v=-PO8ybJ0c44
Those are generally called trammel points. By drilling into the end of the bolts and inserting a tungsten from a tig torch that has been sharpened to a point will stay sharp a lot longer than a common bolt will.
Set the edge of the trammels on opposite legs of a framing square to use as layout guides for marking stringers for stairs
Thanks orioncons36! We've added your Trammel Points to our Measuring and Marking category,
as well as to your builder page: orioncons36's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-trammel-points-3"> <img src="/uploads/254239/homemade-trammel-points-3.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-trammel-points-3">Trammel Points</a> <span> by <a href="https://www.homemadetools.net/builder/orioncons36">orioncons36</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/trammel'>trammel</a>, <a href='https://www.homemadetools.net/tag/scribe'>scribe</a> </div> </div> </div> </div>
Thanks orioncons36! We've added your Grinder Holder to our Storage and Organization category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-grinder-holder-2"> <img src="/uploads/254244/homemade-grinder-holder-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-grinder-holder-2">Grinder Holder</a> <span> by <a href="https://www.homemadetools.net/builder/orioncons36">orioncons36</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/angle-grinder'>angle grinder</a>, <a href='https://www.homemadetools.net/tag/holder'>holder</a> </div> </div> </div> </div>
I have a simple rack next to the vice for the small angle grinders but never thought of making a portable/transportable one. Great idea.
Been thinking I need something like that for welding torches as well.
Thank you.
