Thread: DIY Rivnut Tool
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    DIY Rivnut Tool
    Riveter for rivet nuts suitable for Num 3,4,5,6,8.
    Materials
    Flat bar 20x3mm
    Bolts/long nuts M12x1.75mm (If I remake it I will use M12x1.25mm)
    Small pieces of left over steel
    I havenít a lathe so I made the needed fittings using the same way
    that I had made the threaded insert for my angle grinder.
    Place/secure a piece of steel 30x30mm at my drill press
    Make an M12x1.75 threat
    And using the threat makes the needed fittings.
  2. The Following 3 Users Say Thank You to kess For This Useful Post:
    Home-PC (Jun 11, 2021), Jon (Jun 10, 2021), that_other_guy (Jun 14, 2021)
    Thanks kess! We've added your Rivnut Tool to our Fastening category,
    as well as to your builder page: kess's Homemade Tools. Your receipt:
    kess (Jun 10, 2021)
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Rive Nut Tool Plans
    Searching at my pc today for something I found a plan that I had made at 03.20.2017 that I had forgotten it.
    So I decided to make a quick video and uploaded. Perhaps could be useful for someone.
    It is two somewhat similar versions with M10 bolts/nuts for rive nuts from Num3~6 or using M12 bolts/nuts for Num3~8.
  6. The Following User Says Thank You to kess For This Useful Post:
